► Text zeigen
2017-04-22 23:03:54,442 [main] INFO com.bwssystems.HABridge.HABridge - HA Bridge (v4.5.0) starting....
2017-04-22 23:03:54,496 [main] INFO com.bwssystems.HABridge.BridgeSettings - reading from config file: /home/pi/habridge/data/habridge.config
2017-04-22 23:03:54,757 [main] WARN com.bwssystems.HABridge.BridgeSettings - The upnp config address, 192.168.1.1, does not match any known IP's on this host.
2017-04-22 23:03:56,519 [main] INFO com.bwssystems.HABridge.HABridge - HA Bridge initializing....
2017-04-22 23:03:56,557 [main] INFO com.bwssystems.HABridge.SystemControl - System control service started....
2017-04-22 23:03:56.605:INFO::Thread-0: Logging initialized @3201ms
2017-04-22 23:03:56,623 [main] INFO com.bwssystems.HABridge.util.UDPDatagramSender - Initializing UDP response Socket...
2017-04-22 23:03:56,632 [main] WARN com.bwssystems.HABridge.util.UDPDatagramSender - UDP Response Port is in use, starting loop to find open port for 20 tries - configured port is: 50000
2017-04-22 23:03:56,633 [main] INFO com.bwssystems.HABridge.util.UDPDatagramSender - UDP response Seocket initialized to: 50001
2017-04-22 23:03:56,640 [main] INFO com.bwssystems.HABridge.plugins.harmony.HarmonyHome - Harmony Home created. No Harmony devices configured.
2017-04-22 23:03:56,646 [main] INFO com.bwssystems.HABridge.plugins.NestBridge.NestHome - Nest Home created. No Nest configured.
2017-04-22 23:03:56,649 [main] INFO com.bwssystems.HABridge.plugins.hue.HueHome - Hue passthru Home created.
2017-04-22 23:03:56,832 [Thread-0] INFO spark.webserver.JettySparkServer - == Spark has ignited ...
2017-04-22 23:03:56,837 [Thread-0] INFO spark.webserver.JettySparkServer - >> Listening on 192.168.178.29:9850
2017-04-22 23:03:56.846:INFO:oejs.Server:Thread-0: jetty-9.3.z-SNAPSHOT
2017-04-22 23:03:56.959:INFO:oejs.ServerConnector:Thread-0: Started ServerConnector@8a2d05{HTTP/1.1,[http/1.1]}{192.168.178.29:9850}
2017-04-22 23:03:56.961:INFO:oejs.Server:Thread-0: Started @3562ms
2017-04-22 23:03:57,315 [main] INFO com.bwssystems.HABridge.plugins.hal.HalHome - HAL Home created. No HAL devices configured.
2017-04-22 23:03:57,318 [main] INFO com.bwssystems.HABridge.plugins.mqtt.MQTTHome - MQTT Home created. No MQTT Clients configured.
2017-04-22 23:03:57,321 [main] INFO com.bwssystems.HABridge.plugins.hass.HassHome - HomeAssistant Home created. No HomeAssistants configured.
2017-04-22 23:03:57,324 [main] INFO com.bwssystems.HABridge.plugins.exec.CommandHome - Command Home for system program execution created.
2017-04-22 23:03:57,347 [main] INFO com.bwssystems.HABridge.plugins.http.HTTPHome - Http Home created.
2017-04-22 23:03:57,350 [main] INFO com.bwssystems.HABridge.plugins.tcp.TCPHome - TCP Home created.
2017-04-22 23:03:57,352 [main] INFO com.bwssystems.HABridge.plugins.udp.UDPHome - UDP Home created.
2017-04-22 23:03:57,355 [main] INFO com.bwssystems.HABridge.plugins.vera.VeraHome - Vera Home created. No Veras configured.
2017-04-22 23:03:57,358 [main] INFO com.bwssystems.HABridge.plugins.domoticz.DomoticzHome - Domoticz Home created. No Domoticz devices configured.
2017-04-22 23:03:57,361 [main] INFO com.bwssystems.HABridge.plugins.somfy.SomfyHome - Somfy Home created. No Somfys configured.
2017-04-22 23:03:57,365 [main] INFO com.bwssystems.HABridge.plugins.lifx.LifxHome - LifxDevice Home created. No LifxDevices configured.
2017-04-22 23:03:57,391 [main] INFO com.bwssystems.HABridge.devicemanagmeent.DeviceResource - HABridge device management service started....
2017-04-22 23:03:57,435 [main] INFO com.bwssystems.HABridge.upnp.UpnpSettingsResource - Hue description service started....
2017-04-22 23:03:57,451 [main] INFO com.bwssystems.HABridge.hue.HueMulator - Hue emulator service started....
2017-04-22 23:03:57,506 [main] INFO com.bwssystems.HABridge.upnp.UpnpListener - UPNP Discovery Listener starting....
2017-04-22 23:03:57,508 [main] INFO com.bwssystems.HABridge.upnp.UpnpListener - Traceupnp: wlan0 ... has addr /fe80:0:0:0:759a:921a:c06b:209c%wlan0
2017-04-22 23:03:57,509 [main] INFO com.bwssystems.HABridge.upnp.UpnpListener - Traceupnp: docker0 ... has addr /fe80:0:0:0:134e:dd1e:b702:9870%docker0
2017-04-22 23:03:57,509 [main] INFO com.bwssystems.HABridge.upnp.UpnpListener - Traceupnp: docker0 ... has addr /172.17.0.1
2017-04-22 23:03:57,510 [main] INFO com.bwssystems.HABridge.upnp.UpnpListener - Traceupnp: Adding docker0 to our interface set
2017-04-22 23:03:57,510 [main] INFO com.bwssystems.HABridge.upnp.UpnpListener - Traceupnp: eth0 ... has addr /fe80:0:0:0:6dc1:d0bf:3b55:732f%eth0
2017-04-22 23:03:57,511 [main] INFO com.bwssystems.HABridge.upnp.UpnpListener - Traceupnp: eth0 ... has addr /192.168.178.29
2017-04-22 23:03:57,511 [main] INFO com.bwssystems.HABridge.upnp.UpnpListener - Traceupnp: Adding eth0 to our interface set
2017-04-22 23:03:57,511 [main] INFO com.bwssystems.HABridge.upnp.UpnpListener - Traceupnp: lo ... has addr /0:0:0:0:0:0:0:1%lo
2017-04-22 23:03:57,511 [main] INFO com.bwssystems.HABridge.upnp.UpnpListener - Traceupnp: lo ... has addr /127.0.0.1
2017-04-22 23:03:57,511 [main] INFO com.bwssystems.HABridge.upnp.UpnpListener - Traceupnp: Adding lo to our interface set
2017-04-22 23:03:57,512 [main] INFO com.bwssystems.HABridge.upnp.UpnpListener - UPNP Discovery Listener running and ready....
2017-04-22 23:04:00,274 [main] INFO com.bwssystems.HABridge.upnp.UpnpListener - Traceupnp: isSSDPDiscovery found message to be an M-SEARCH message.
2017-04-22 23:04:00,276 [main] INFO com.bwssystems.HABridge.upnp.UpnpListener - Traceupnp: isSSDPDiscovery found message to be valid under strict rules - strict: true
2017-04-22 23:04:00,277 [main] INFO com.bwssystems.HABridge.upnp.UpnpListener - Traceupnp: SSDP packet from 192.168.178.23:4397, body: M-SEARCH * HTTP/1.1
MX: 5
ST: upnp:rootdevice
MAN: "ssdp:discover"
User-Agent: UPnP/1.0 DLNADOC/1.50 Platinum/1.0.5.13
Connection: close
Host: 239.255.255.250:1900
2017-04-22 23:04:00,280 [main] INFO com.bwssystems.HABridge.upnp.UpnpListener - Traceupnp: sendUpnpResponse discovery responseTemplate1 is <<<HTTP/1.1 200 OK
HOST: 239.255.255.250:1900
CACHE-CONTROL: max-age=100
EXT:
SERVER: Linux/3.14.0 UPnP/1.0 IpBridge/1.15.0
hue-bridgeid: 000088FFFE00BBEE
ST: upnp:rootdevice
USN: uuid:2f402f80-da50-11e1-9b23-00008800bbee::upnp:rootdevice
2017-04-22 23:04:00,283 [main] INFO com.bwssystems.HABridge.upnp.UpnpListener - Traceupnp: sendUpnpResponse discovery responseTemplate2 is <<<HTTP/1.1 200 OK
EXT:
ST: uuid:2f402f80-da50-11e1-9b23-00008800bbee
2017-04-22 23:04:00,289 [main] INFO com.bwssystems.HABridge.upnp.UpnpListener - Traceupnp: sendUpnpResponse discovery responseTemplate3 is <<<HTTP/1.1 200 OK
EXT:
ST: urn:schemas-upnp-org:device:basic:1
2017-04-22 23:04:00,295 [main] INFO com.bwssystems.HABridge.upnp.UpnpListener - Traceupnp: isSSDPDiscovery found message to be an M-SEARCH message.
2017-04-22 23:04:00,296 [main] INFO com.bwssystems.HABridge.upnp.UpnpListener - Traceupnp: isSSDPDiscovery found message to be valid under strict rules - strict: true
2017-04-22 23:04:00,297 [main] INFO com.bwssystems.HABridge.upnp.UpnpListener - Traceupnp: SSDP packet from 192.168.178.23:4397, body: M-SEARCH * HTTP/1.1
MX: 5
ST: upnp:rootdevice
Connection: close
2017-04-22 23:04:00,299 [main] INFO com.bwssystems.HABridge.upnp.UpnpListener - Traceupnp: sendUpnpResponse discovery responseTemplate1 is <<<HTTP/1.1 200 OK
EXT:
ST: upnp:rootdevice
2017-04-22 23:04:00,301 [main] INFO com.bwssystems.HABridge.upnp.UpnpListener - Traceupnp: sendUpnpResponse discovery responseTemplate2 is <<<HTTP/1.1 200 OK
EXT:
2017-04-22 23:04:00,303 [main] INFO com.bwssystems.HABridge.upnp.UpnpListener - Traceupnp: sendUpnpResponse discovery responseTemplate3 is <<<HTTP/1.1 200 OK
EXT:
2017-04-22 23:04:21,507 [qtp25239806-16] INFO com.bwssystems.HABridge.SystemControl - Link button pressed....
2017-04-22 23:04:21,578 [qtp25239806-20] INFO com.bwssystems.HABridge.hue.HueMulator - Traceupnp: hue api user create requested: {"devicetype":"test_ha_bridge"} from 192.168.178.24
2017-04-22 23:04:21,620 [qtp25239806-20] INFO com.bwssystems.HABridge.hue.HueMulator - Traceupnp: hue api user create requested for device type: test_ha_bridge and username: 2a46d383b7674cefb86ffe7e80095c79
2017-04-22 23:04:33,871 [main] INFO com.bwssystems.HABridge.upnp.UpnpListener - Traceupnp: sendUpnpNotify notifyTemplate is <<<NOTIFY * HTTP/1.1
NTS: ssdp:alive
NT: uuid:2f402f80-da50-11e1-9b23-00008800bbee
2017-04-22 23:04:37,635 [main] INFO com.bwssystems.HABridge.upnp.UpnpListener - UPNP Discovery Listener - ended, restart found
2017-04-22 23:04:37,636 [main] INFO com.bwssystems.HABridge.HABridge - HA Bridge (v4.5.0) reinitialization requessted....
2017-04-22 23:04:37,638 [main] INFO spark.webserver.JettySparkServer - >>> Spark shutting down ...
2017-04-22 23:04:37.671:INFO:oejs.ServerConnector:main: Stopped ServerConnector@8a2d05{HTTP/1.1,[http/1.1]}{192.168.178.29:9850}
2017-04-22 23:04:37,682 [main] INFO spark.webserver.JettySparkServer - done
2017-04-22 23:04:42,683 [main] INFO com.bwssystems.HABridge.BridgeSettings - reading from config file: /home/pi/habridge/data/habridge.config
2017-04-22 23:04:42,699 [main] WARN com.bwssystems.HABridge.BridgeSettings - The upnp config address, 192.168.1.1, does not match any known IP's on this host.
2017-04-22 23:04:42,722 [main] INFO com.bwssystems.HABridge.HABridge - HA Bridge initializing....
2017-04-22 23:04:42,727 [main] INFO com.bwssystems.HABridge.SystemControl - System control service started....
2017-04-22 23:04:42,731 [Thread-13] INFO spark.webserver.JettySparkServer - == Spark has ignited ...
2017-04-22 23:04:42,732 [Thread-13] INFO spark.webserver.JettySparkServer - >> Listening on 192.168.178.29:9850
2017-04-22 23:04:42,732 [main] INFO com.bwssystems.HABridge.util.UDPDatagramSender - Initializing UDP response Socket...
2017-04-22 23:04:42.733:INFO:oejs.Server:Thread-13: jetty-9.3.z-SNAPSHOT
2017-04-22 23:04:42,733 [main] WARN com.bwssystems.HABridge.util.UDPDatagramSender - UDP Response Port is in use, starting loop to find open port for 20 tries - configured port is: 50000
2017-04-22 23:04:42,735 [main] INFO com.bwssystems.HABridge.util.UDPDatagramSender - UDP response Seocket initialized to: 50001
2017-04-22 23:04:42,736 [main] INFO com.bwssystems.HABridge.plugins.harmony.HarmonyHome - Harmony Home created. No Harmony devices configured.
2017-04-22 23:04:42,737 [main] INFO com.bwssystems.HABridge.plugins.NestBridge.NestHome - Nest Home created. No Nest configured.
2017-04-22 23:04:42,738 [main] INFO com.bwssystems.HABridge.plugins.hue.HueHome - Hue passthru Home created.
2017-04-22 23:04:42.740:INFO:oejs.ServerConnector:Thread-13: Started ServerConnector@1c6fab8{HTTP/1.1,[http/1.1]}{192.168.178.29:9850}
2017-04-22 23:04:42.747:INFO:oejs.Server:Thread-13: Started @49347ms
2017-04-22 23:04:42,780 [main] INFO com.bwssystems.HABridge.plugins.hal.HalHome - HAL Home created. No HAL devices configured.
2017-04-22 23:04:42,781 [main] INFO com.bwssystems.HABridge.plugins.mqtt.MQTTHome - MQTT Home created. No MQTT Clients configured.
2017-04-22 23:04:42,782 [main] INFO com.bwssystems.HABridge.plugins.hass.HassHome - HomeAssistant Home created. No HomeAssistants configured.
2017-04-22 23:04:42,782 [main] INFO com.bwssystems.HABridge.plugins.exec.CommandHome - Command Home for system program execution created.
2017-04-22 23:04:42,801 [main] INFO com.bwssystems.HABridge.plugins.http.HTTPHome - Http Home created.
2017-04-22 23:04:42,801 [main] INFO com.bwssystems.HABridge.plugins.tcp.TCPHome - TCP Home created.
2017-04-22 23:04:42,802 [main] INFO com.bwssystems.HABridge.plugins.udp.UDPHome - UDP Home created.
2017-04-22 23:04:42,802 [main] INFO com.bwssystems.HABridge.plugins.vera.VeraHome - Vera Home created. No Veras configured.
2017-04-22 23:04:42,802 [main] INFO com.bwssystems.HABridge.plugins.domoticz.DomoticzHome - Domoticz Home created. No Domoticz devices configured.
2017-04-22 23:04:42,803 [main] INFO com.bwssystems.HABridge.plugins.somfy.SomfyHome - Somfy Home created. No Somfys configured.
2017-04-22 23:04:42,803 [main] INFO com.bwssystems.HABridge.plugins.lifx.LifxHome - LifxDevice Home created. No LifxDevices configured.
2017-04-22 23:04:42,810 [main] INFO com.bwssystems.HABridge.devicemanagmeent.DeviceResource - HABridge device management service started....
2017-04-22 23:04:42,815 [main] INFO com.bwssystems.HABridge.upnp.UpnpSettingsResource - Hue description service started....
2017-04-22 23:04:42,816 [main] INFO com.bwssystems.HABridge.hue.HueMulator - Hue emulator service started....
2017-04-22 23:04:42,819 [main] INFO com.bwssystems.HABridge.upnp.UpnpListener - UPNP Discovery Listener starting....
2017-04-22 23:04:42,820 [main] INFO com.bwssystems.HABridge.upnp.UpnpListener - Traceupnp: wlan0 ... has addr /fe80:0:0:0:759a:921a:c06b:209c%wlan0
2017-04-22 23:04:42,821 [main] INFO com.bwssystems.HABridge.upnp.UpnpListener - Traceupnp: docker0 ... has addr /fe80:0:0:0:134e:dd1e:b702:9870%docker0
2017-04-22 23:04:42,821 [main] INFO com.bwssystems.HABridge.upnp.UpnpListener - Traceupnp: docker0 ... has addr /172.17.0.1
2017-04-22 23:04:42,821 [main] INFO com.bwssystems.HABridge.upnp.UpnpListener - Traceupnp: Adding docker0 to our interface set
2017-04-22 23:04:42,821 [main] INFO com.bwssystems.HABridge.upnp.UpnpListener - Traceupnp: eth0 ... has addr /fe80:0:0:0:6dc1:d0bf:3b55:732f%eth0
2017-04-22 23:04:42,821 [main] INFO com.bwssystems.HABridge.upnp.UpnpListener - Traceupnp: eth0 ... has addr /192.168.178.29
2017-04-22 23:04:42,822 [main] INFO com.bwssystems.HABridge.upnp.UpnpListener - Traceupnp: Adding eth0 to our interface set
2017-04-22 23:04:42,822 [main] INFO com.bwssystems.HABridge.upnp.UpnpListener - Traceupnp: lo ... has addr /0:0:0:0:0:0:0:1%lo
2017-04-22 23:04:42,822 [main] INFO com.bwssystems.HABridge.upnp.UpnpListener - Traceupnp: lo ... has addr /127.0.0.1
2017-04-22 23:04:42,822 [main] INFO com.bwssystems.HABridge.upnp.UpnpListener - Traceupnp: Adding lo to our interface set
2017-04-22 23:04:42,822 [main] INFO com.bwssystems.HABridge.upnp.UpnpListener - UPNP Discovery Listener running and ready....
2017-04-22 23:04:44,668 [qtp28372103-27] INFO com.bwssystems.HABridge.upnp.UpnpSettingsResource - Traceupnp: upnp device settings requested: from 192.168.178.24:9850
2017-04-22 23:04:44,672 [qtp28372103-27] INFO com.bwssystems.HABridge.upnp.UpnpSettingsResource - Traceupnp: upnp device settings template filled with address: 192.168.1.1 and port: 9850
2017-04-22 23:04:51,510 [Timer-0] INFO com.bwssystems.HABridge.LinkButtonPressed - Link button time ended....
2017-04-22 23:05:03,023 [main] INFO com.bwssystems.HABridge.upnp.UpnpListener - Traceupnp: sendUpnpNotify notifyTemplate is <<<NOTIFY * HTTP/1.1
NTS: ssdp:alive
2017-04-22 23:05:12,958 [main] INFO com.bwssystems.HABridge.upnp.UpnpListener - Traceupnp: isSSDPDiscovery found message to be an M-SEARCH message.
2017-04-22 23:05:12,959 [main] INFO com.bwssystems.HABridge.upnp.UpnpListener - Traceupnp: isSSDPDiscovery found message to be valid under strict rules - strict: true
2017-04-22 23:05:12,959 [main] INFO com.bwssystems.HABridge.upnp.UpnpListener - Traceupnp: SSDP packet from 192.168.178.23:4397, body: M-SEARCH * HTTP/1.1
MX: 5
ST: upnp:rootdevice
Connection: close
2017-04-22 23:05:12,960 [main] INFO com.bwssystems.HABridge.upnp.UpnpListener - Traceupnp: sendUpnpResponse discovery responseTemplate1 is <<<HTTP/1.1 200 OK
EXT:
ST: upnp:rootdevice
2017-04-22 23:05:12,961 [main] INFO com.bwssystems.HABridge.upnp.UpnpListener - Traceupnp: sendUpnpResponse discovery responseTemplate2 is <<<HTTP/1.1 200 OK
EXT:
2017-04-22 23:05:12,962 [main] INFO com.bwssystems.HABridge.upnp.UpnpListener - Traceupnp: sendUpnpResponse discovery responseTemplate3 is <<<HTTP/1.1 200 OK
EXT:
2017-04-22 23:05:12,963 [main] INFO com.bwssystems.HABridge.upnp.UpnpListener - Traceupnp: isSSDPDiscovery found message to be an M-SEARCH message.
2017-04-22 23:05:12,963 [main] INFO com.bwssystems.HABridge.upnp.UpnpListener - Traceupnp: isSSDPDiscovery found message to be valid under strict rules - strict: true
2017-04-22 23:05:12,963 [main] INFO com.bwssystems.HABridge.upnp.UpnpListener - Traceupnp: SSDP packet from 192.168.178.23:4397, body: M-SEARCH * HTTP/1.1
MX: 5
ST: upnp:rootdevice
Connection: close
2017-04-22 23:05:12,964 [main] INFO com.bwssystems.HABridge.upnp.UpnpListener - Traceupnp: sendUpnpResponse discovery responseTemplate1 is <<<HTTP/1.1 200 OK
EXT:
ST: upnp:rootdevice
2017-04-22 23:05:12,969 [main] INFO com.bwssystems.HABridge.upnp.UpnpListener - Traceupnp: sendUpnpResponse discovery responseTemplate2 is <<<HTTP/1.1 200 OK
EXT:
2017-04-22 23:05:12,970 [main] INFO com.bwssystems.HABridge.upnp.UpnpListener - Traceupnp: sendUpnpResponse discovery responseTemplate3 is <<<HTTP/1.1 200 OK
EXT:
2017-04-22 23:05:35,501 [main] INFO com.bwssystems.HABridge.upnp.UpnpListener - Traceupnp: sendUpnpNotify notifyTemplate is <<<NOTIFY * HTTP/1.1
NTS: ssdp:alive
MX: 5
ST: upnp:rootdevice
Connection: close
EXT:
ST: upnp:rootdevice
EXT:
EXT:
MX: 5
ST: upnp:rootdevice
Connection: close
EXT:
ST: upnp:rootdevice
EXT:
EXT:
NTS: ssdp:alive
NTS: ssdp:alive
MX: 5
ST: upnp:rootdevice
Connection: close
EXT:
ST: upnp:rootdevice
EXT:
EXT:
MX: 5
ST: upnp:rootdevice
Connection: close
EXT:
ST: upnp:rootdevice
EXT:
EXT:
NTS: ssdp:alive
