Wie ist die Konsolen Ausgabe von ./bin/Alexa ?
Und was machst du nach dem Start? Doch wohl nicht das Konsolen Fenster schließen?
Alexa und FHEM
coolerkerl
richtig! Konsole muss auf bleiben oder du musst das entwickelte Script verwenden. Damit der Dienst dauerhaft läuft.
Gesendet von meinem Power mit Tapatalk
AlienElement
Konsole bleibt natürlich auf. Die Ausgabe sieht so aus:
pi@raspberrypi:~/alexa-fhem $ ./bin/alexa
[11/27/2016, 4:12:13 PM] using /home/pi/.alexa/config.json
[11/27/2016, 4:12:13 PM] ---
[11/27/2016, 4:12:13 PM] this alexa-fhem 0.1.3
[11/27/2016, 4:12:13 PM] Trying NAT-UPNP ...
[11/27/2016, 4:12:13 PM] Fetching FHEM devices...
[11/27/2016, 4:12:13 PM] [FHEM] Checking devices and attributes...
[11/27/2016, 4:12:13 PM] [FHEM] executing: http://192.168.178.34:8083/fhem?cmd=%7B ... )%7D&XHR=1
[11/27/2016, 4:12:13 PM] [FHEM] executing: http://192.168.178.34:8083/fhem?cmd=jso ... lexa&XHR=1
[11/27/2016, 4:12:13 PM] [FHEM] starting longpoll: http://192.168.178.34:8083/fhem.pl?XHR= ... 0259533333
[11/27/2016, 4:12:13 PM] [FHEM] Fetching FHEM devices...
[11/27/2016, 4:12:13 PM] [FHEM] fetching: http://192.168.178.34:8083/fhem?cmd=jso ... lexa&XHR=1
[11/27/2016, 4:12:13 PM] Server listening on: https://:::3000
[11/27/2016, 4:12:13 PM] [FHEM] no alexa device found. please define it.
[11/27/2016, 4:12:13 PM] [FHEM] got: 6 results
[11/27/2016, 4:12:13 PM] [FHEM] HUEDevice1 is switch
[11/27/2016, 4:12:13 PM] [FHEM] HUEDevice1 has
[11/27/2016, 4:12:13 PM] [FHEM] On [onoff;on,off]
[11/27/2016, 4:12:13 PM] [FHEM] Brightness [bri]
[11/27/2016, 4:12:13 PM] [FHEM] Hue [hue;hue;0-65535]
[11/27/2016, 4:12:13 PM] [FHEM] Saturation [sat;sat;0-254]
[11/27/2016, 4:12:13 PM] [FHEM] colormode [colormode]
[11/27/2016, 4:12:13 PM] [FHEM] xy [xy]
2016-11-27 16:12:13 caching: HUEDevice1-onoff: 1
2016-11-27 16:12:13 caching: HUEDevice1-bri: 137
2016-11-27 16:12:13 caching: HUEDevice1-hue: 41859
2016-11-27 16:12:13 caching: HUEDevice1-sat: 238
2016-11-27 16:12:13 caching: HUEDevice1-colormode: xy
2016-11-27 16:12:13 caching: HUEDevice1-xy: 0.1713,0.2174
[11/27/2016, 4:12:13 PM] [FHEM] HUEDevice2 is switch
[11/27/2016, 4:12:13 PM] [FHEM] HUEDevice2 has
2016-11-27 16:12:13 caching: HUEDevice2-onoff: 0
2016-11-27 16:12:13 caching: HUEDevice2-bri: 0
2016-11-27 16:12:13 caching: HUEDevice2-hue: 12807
2016-11-27 16:12:13 caching: HUEDevice2-sat: 51
2016-11-27 16:12:13 caching: HUEDevice2-colormode: xy
2016-11-27 16:12:13 caching: HUEDevice2-xy: 0.4574,0.4119
[11/27/2016, 4:12:13 PM] [FHEM] HUEDevice3 is switch
[11/27/2016, 4:12:13 PM] [FHEM] HUEDevice3 has
2016-11-27 16:12:13 caching: HUEDevice3-onoff: 1
2016-11-27 16:12:13 caching: HUEDevice3-bri: 137
2016-11-27 16:12:13 caching: HUEDevice3-hue: 41859
2016-11-27 16:12:13 caching: HUEDevice3-sat: 238
2016-11-27 16:12:13 caching: HUEDevice3-colormode: xy
2016-11-27 16:12:13 caching: HUEDevice3-xy: 0.1713,0.2174
[11/27/2016, 4:12:13 PM] [FHEM] HUEDevice4 is switch
[11/27/2016, 4:12:13 PM] [FHEM] HUEDevice4 has
2016-11-27 16:12:13 caching: HUEDevice4-onoff: 1
2016-11-27 16:12:13 caching: HUEDevice4-bri: 185
2016-11-27 16:12:13 caching: HUEDevice4-hue: 41859
2016-11-27 16:12:13 caching: HUEDevice4-sat: 238
2016-11-27 16:12:13 caching: HUEDevice4-colormode: xy
2016-11-27 16:12:13 caching: HUEDevice4-xy: 0.1713,0.2174
[11/27/2016, 4:12:13 PM] [FHEM] Lichterkette is switch
[11/27/2016, 4:12:13 PM] [FHEM] Lichterkette has
[11/27/2016, 4:12:13 PM] [FHEM] Custom Voltage [voltage]
[11/27/2016, 4:12:13 PM] [FHEM] Custom Current [current]
[11/27/2016, 4:12:13 PM] [FHEM] Custom Power [power]
[11/27/2016, 4:12:13 PM] [FHEM] On [state;on,off]
2016-11-27 16:12:13 caching: Lichterkette-voltage: 233.348073
[11/27/2016, 4:12:13 PM] [FHEM] caching: Custom Voltage: 233.348073 (as number; from '233.348073')
2016-11-27 16:12:13 caching: Lichterkette-current: 0.012867
[11/27/2016, 4:12:13 PM] [FHEM] caching: Custom Current: 0.012867 (as number; from '0.012867')
2016-11-27 16:12:13 caching: Lichterkette-power: 0
[11/27/2016, 4:12:13 PM] [FHEM] caching: Custom Power: 0 (as number; from '0')
2016-11-27 16:12:13 caching: Lichterkette-state: off
[11/27/2016, 4:12:13 PM] [FHEM] Test is switch
[11/27/2016, 4:12:13 PM] [FHEM] Test has
[11/27/2016, 4:12:13 PM] Current external IP address: 87.179.39.254
Coolzero1982
Welchen Skill nutzt du in der alexa App?
coolerkerl
Für mich sieht es so aus sls hättest du keinen Raum alexa
Auf ein Device in FHEM gehen, auf attr Room einen zusätzlichen Raum alexa erstellen. auf attr klicken und Save Config
coolerkerl
nach Recherche im Forum fand ich noch den Hinweis das FHEM nicht aktuell ist. Bitte mit Update in die FHEM Kommandozeile mal die aktuellen Module laden.
AlienElement
Wie meinst du das?Coolzero1982 hat geschrieben:Welchen Skill nutzt du in der alexa App?
AlienElement
Doch, hab einen Raum alexa, in dem alle Geräte inkl. Dummy sind. Deswegen wundert mich ja die Meldung "[FHEM] no alexa device found. please define it." auch so.coolerkerl hat geschrieben:Für mich sieht es so aus sls hättest du keinen Raum alexa
Hab inzwischen den FHEM-Skill erneut angelegt, alles neu gestartet, nach Geräten gesucht, aber weiterhin wird kein Device in Alexa angezeigt. Per FHEM kann ich übrigens die Geräte einwandfrei manuell und automatisiert schalten.
coolerkerl
Ja! das hatte ich schon verstanden. Ich bin mir nicht mehr sicher ob ich nicht im Laufe der Installation mal ein define alexa alexa ausführen musste. . das würde ja passen. Außerdem hatte ich dir geschrieben das evtl dein FHEM nicht aktuell ist. schon mal in FHEM update eingetippt? Check das mal.. bedankt
gesendet von meinem UlefonePower mit Tapatalk
AlienElement
FHEM ist aktuell. Durch define alexa alexa tritt die obige Meldung nicht mehr auf. Geräte findet Alexa dennoch nicht.
